today i was installing the brake and clutch pedal
and wanted to align them so they are on the same height.
i set the clutch pedal as it should and hits the rubber bumper
thats ok
while the brake pedal is not attached to the clevis of the booster
and when i pull the pedal and hits the rubber bumper it lines up perfectly
with the clutch
but then the booster rod with the clevis is 3/4 of an inch to short
is this typical for power brakes on 63 ?
this how it looked like before the restoration (same as it is now)
thats ok
with the clutch
