Motor mounts - NCRS Discussion Boards
Motor mounts
  • John M.
    • January 1, 1998
    • 813
    Motor mounts
    67 327-300 motor project.
    I've just finished rebuilding this engine and am getting ready to put it in a car. I have the original motor mounts and they look pretty good. I was going to buy new ones but heard somewhere there's a problem with the lower ignition shields and these new mounts. Should I use the old ones? The engine has been sitting since '78. I'm planning to rev this motor pretty good and have it dyno tested in the chassis.
    John McRae 30025
  • Grant M.
    • August 31, 1995
    • 448
    Re: Motor mounts
    John,
    The "new" mounts you refer to are likely the later safety design which does require some cutting of the lower "V" spark plug wire shields for clearance. The new mounts generally come with an instruction page showing the area that must be cut out. All that to say, while they're safer, the shield cut-out probably won't pass NCRS judging without a deduction.
    Grant
    • Eugene B.
      • May 31, 1988
      • 710
      Re: Motor mounts
      John,
      When I replaced the motor mounts in my '65, I purchased original (non-interlocking design) from Long Island Corvette. They were very nice and no modification to ignition shielding was required.
      Good luck on your restoration.
      Gene
      • Noel K.
        • November 1, 2004
        • 84
        Re: Motor mounts
        regardless of which mounts you use, make sure you check the judging manual. one bolt/nut combination goes in one way, the other side is the opposite. don't remember which, but they don't both in the same way. the judges will look for this.
        Noel, the voice of experience, Kendall !
        • Joseph T.
          • March 1, 1986
          • 169
          Re: Motor mounts
          John,
          Just replaced the original motor mounts in my 1967 327/300HP. My original mounts exhibited a little cracking in the rubber. I opted to Purchased a set from L.I. Corvette supply and the fit and look is spot on. Good Luck.
          • John M.
            • January 1, 1998
            • 813
            Re: Motor mounts
            Thanks for the replies guys. I never thought to look in the LIC catalog after hearing the the replacements caused this problem.
            John
              Re: Motor mounts
              The passenger side through-bolt must be installed rear-to-front or you'll have to remove the fuel pump to get it out; the fuel pump was already on the engine when the plant installed that bolt, so they're rear-to-front.
