Re: Ignition Coil Testing
All,
Separate question on the coil. I've installed the Pertronix coil and electronic ignition hardware and have noticed that the coil runs VERY hot - I'm talking over 200 F hot. This is with the ballast resistor out of the circuit (which is the way a Pertronix rep told me to do it). With the ballast resitor in, the coil is much cooler but, understandably, the resistor is then melting thru the firewall (almost).
Pertronix says the coil is able, and should, run very hot ( near 300 F, they claim). Still sounds bad to me......?
Thanks, Mark
All,
Thanks, Mark
