C2 Caliper Rattles - NCRS Discussion Boards
C2 Caliper Rattles
  • Brian K.
    • September 19, 2007
    • 174
    C2 Caliper Rattles
    I have one caliper (RF) that the pads rattle a lot. The caliper is worn a very small amount (where the pad ends contact) & permit a little end to end movement. Is there any solution available that actually works to hold them in place?
    Thank you.
    66 Coupe
    66 Convertible
    2022 2LT Coupe
    67 Chevelle SS396
    67 XLCH HD Sportster
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C2 Caliper Rattles
    It is common for them to move back and forth and make sound when going from reverse to forward. If they are rattling when you hit a bump, something else is wrong. There should be enough spring pressure on the pistons to keep that from happening.
      • 43297
      Wayne and Brian-----
      I agree; I can't see any reason for the front pads to "rattle", regardless of any wear on the calipers where the pad backing plates contact it. One thing that can cause "squeaking", though, is excessive runout on the rotor. This causes the pads to move inward and outward and cause "squeaking" as the pad backing plates move against the calipers. This can occur with either front or rear brakes.
      • Wayne W.
        • April 30, 1982
        • 3605
        True, but it is my observation that most of the squeaking is caused by the pad rubbing against the retainer pin.
        • Brian K.
          • 174
          It rattles when hitting bumps. I rebuilt that caliper because it was weeping & saw nothing wrong. Any other ideas? I have zero squeak issues.
          66 Coupe
          66 Convertible
          2022 2LT Coupe
          67 Chevelle SS396
          • Wayne W.
            • April 30, 1982
            • 3605
            Make absolutely sure the bolts holding the caliper on are tight. They rattle like crazy when the bolts are loose.
            • Brian K.
              • 174
              Wayne,
              They are as tight as my first employer's wallet! It's definitely the pads rattling.
              66 Coupe
              66 Convertible
              2022 2LT Coupe
              67 Chevelle SS396
              • Wayne W.
                • April 30, 1982
                • 3605
                Wayne,
                If the internal springs are inside those calipers, it would be hard for them to rattle. Now, do you have o-ring type seals or maybe have the springs out?
                The only other thing to rattle would be the pins.
                • Brian K.
                  • 174
                  As I said, I rebuilt that caliper but it was a few years back. I know they have springs and if they weren't there, I should have noticed but don't recall. Then again, they may be weak & not doing the job correctly. They are the old style seals, not o-ring. Maybe it's time to pull apart & put new springs & seals.
                  66 Coupe
                  66 Convertible
                  2022 2LT Coupe
                  67 Chevelle SS396
