72 ignition shielding - NCRS Discussion Boards
  • Henry A.
    • May 31, 1990
    • 107
    Can someone confirm the ignition shielding for my 72 car. We have recently aquired this car and are headed to Bloomington with it for a survivor certification. In looking the car over there is only a ignition shield over the rear two spark plugs on both sides (including the uprights and the distributor cover). The assembly manual shows this set up also...I have a couple of midyears and they have shields on all of the plugs. So...any insight will be helpful. Thanks, Henry
    Henry Atsma
    54 White/Red
    63 Red/Black SWC
    67 Elkhart Blue/Black BB Roadster
    91 Black/Red ZR1
    96 CE - LT4
    07 Red/Tan
    • 3418
    Re: 72 ignition shielding
    Henry,
    If you're asking about a 350 engine car you're right. There are just shields for the rear pairs of plugs along with the V-shaped shield on each side. This info is in the Tech Guide, Mechanical, Section 10.
    • Jerome P.
      • October 22, 2006
      • 607
      I have a 72 LT1 (SB) and the shielding is correct as you described. Good luck at Bloomington.
      • Henry A.
        • May 31, 1990
        • 107
        Thanks Guys...I really appreciate the confirmation. If you are at Bloomington...look for us...we will have a 72 Blue/black A/C, power windows, tilt tele...I bought the car from the original owner last fall. Thanks again. Henry
        Henry Atsma
        54 White/Red
        63 Red/Black SWC
        91 Black/Red ZR1
        96 CE - LT4
        07 Red/Tan
          • 11689
          Henry,
          I notice that you're from Michigan.
          Where?
          Patrick
          • Henry A.
            • May 31, 1990
            • 107
            Patrick, I live in the Grand Rapids area...and you? Henry
            Henry Atsma
            54 White/Red
            63 Red/Black SWC
            91 Black/Red ZR1
            96 CE - LT4
            07 Red/Tan
              • 11689
              Holland.
              See my e-mail to you.
