63 -65 sb radiator shroud - NCRS Discussion Boards
  • Henry A.
    • May 31, 1990
    • 103
    I am in the process of restoring my 63 coupe and have found that my original shroud has been cut to allow for easier installation around the lower radiator hose. I understand that this was quite common. Since this is a high level restoration I am looking to find a very nice original to purchase for this project. Does anyone have any leads for me? Thanks.
    Henry Atsma
    54 White/Red
    63 Red/Black SWC
    67 Elkhart Blue/Black BB Roadster
    91 Black/Red ZR1
    96 CE - LT4
    07 Red/Tan
  • Bob R.
    • June 30, 2002
    • 1595
    Re: 63 -65 sb radiator shroud
    You can keep an eye on ebay. I have seen them come up from time to time. The 63 radiator shroud is a one year only part. The later years might fit but there is a slight difference in the appearance.
    • Timothy B.
      • April 30, 1983
      • 5186
      Bob,
      What are the differences in the 1963 radiator shroud, I thought 63/65 all the same. I know core support is different, could you be talking about that?
      • Michael H.
        • January 29, 2008
        • 7477
        Originally posted by Timothy Barbieri (6542)
        Bob,
        I'm curious also. There was an early production change for the 63 shroud (slight cut on the right side for the new oil cooler line hole for PG equipped 63's) but I wasn't aware of a change for 64.
        • Bob R.
          • June 30, 2002
          • 1595
          Sorry guys I was thinking of the radiator support.
          • Joel T.
            • April 30, 2005
            • 765
            There's one on e-bay today #190218212668... I thought that I saw one, just checked and it is there.
            Good luck,
            Joel
            • Michael H.
              • January 29, 2008
              • 7477
              Ok, thanks Bob. I was searching my pea brain trying to think if I'd forgotten some change from 63 to 64.
              • Henry A.
                • May 31, 1990
                • 103
                Thanks for the replys. I will check out e-bay...but would rather buy one from one our NCRS brothers. Henry
                Henry Atsma
                54 White/Red
                63 Red/Black SWC
                91 Black/Red ZR1
                96 CE - LT4
                07 Red/Tan
