63 Steering Column Alignment - NCRS Discussion Boards
  • Kenneth B.
    • April 10, 2008
    • 39
    Hello, Folks,
    I recently reinstalled the steering column in my 63 convertible.
    Today I noticed that the column is not perpendicular to the instrument panel (or the firewall, on the engine side); it is angled slightly towards the left inner fenderwell.
    Everything else with the column seems to be OK; it lines up perfectly with the steering box at the rag joint.
    Is this a problem?
    Thanks in advance.
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: 63 Steering Column Alignment
    Mine seems to be cock eyed too, but I recall reading this was planned that way for driver comfort/positioning. I don't recall where I read it, try Noland Adam's book, or even the Judging Guide. Or you can wait for a reply from one of the more knowledgable fellows.
    Stu Fox
    • Joel T.
      • April 30, 2005
      • 765
      Hi,
      The column on my 1963 is basically the same way, slightly off perpendicular. Not a problem.
      Joel
      • Kenneth B.
        • April 10, 2008
        • 39
        Originally posted by Joel Talka (43778)
        Hi,
        Joel
        Thanks to all for the prompt replies.
        That's great news - I was almost afraid to ask for fear of discovering yet another Corvette gremlin.
        Now I can go find something else on the car to stress about!
        • Stuart F.
          • August 31, 1996
          • 4676
          Ken;
          I found reference to the offset steering column in a couple publications describing the original design of the C-2. Basically, a larger hump/center consul was used and the seats were spread to give it more shoulder and hip room (i.e. seats are further apart than on C-1's). I guess the frame is almost a perimeter frame in the passenger compartment, but is narrower in the front and rear for the suspension. To make a long story short; to put you the driver in line with the steering wheel, it was necessary to angle the column a little to the left from where the steering box sits, and is why they used a "rag" joint coupling which acts as a universal joint.
          Stu
