I seem to be finding conflicting data on what is the correct vacuum advance for my 1966 427/390. Can someone give me a "definitive" answer? Thanks, as always.
1966 427/390 vacuum advance
Re: 1966 427/390 vacuum advance
If so it is 24 degrees at 2800 rpm.- Top
And the advance specs for this vacuum unit, from Delco Remy test specifications supplement (green) book are: inches Hg to start advance 5 to 7". Inches Hg for max advance 11.2-12.7". Max distributor advance 8 degrees (equals 16 degrees crank advance).
Now the centrifugal advance is a different story, which Jerry may be quoting.- Top
Curt -- I don't think there's any doubt that the correct vac adv unit for a '66 L36 (either 1111141 or 142 distrib) is the 1115355 unit, as Joe L. (I think) mentioned.
quoting.- Top
