C-3 Rocker Cover Torque - NCRS Discussion Boards
  • Martin N.
    • July 30, 2007
    • 594
    The GM Service Manual calls for 45 inch pounds of torque for the small block V-8 rocker covers. The manual does not stipulate if that torque is for the stamped steel covers or the finned aluminum covers. I would think that looking at the gasket flange thickness differance that there would be 2 differant torque specs. Anyone run across this or have any leakage problems? I'm using the aluminum rocker covers. THANKS for any comments.
    Marty
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: C-3 Rocker Cover Torque
    Check the automatic archive search at the bottom of the page...the answer to your very question per Joe Lucia.
