1965 Turn Signal Flasher Location - NCRS Discussion Boards
  • Michael S.
    • June 7, 2007
    • 82
    The judging guide calls for a turn signal flasher to be attached to a metal clip on the left side radio panel. I have a radio delete car, the metal clip is there but no signal flasher is installed. Should the metal clip be installed even though the flasher is installed in a different location? Also, were there multiple locations for the flashers in 1965?
    Re: 1965 Turn Signal Flasher Location
    Michael -
    The side panel, clip, and flasher are in the same place whether the car has a radio or not; presence/absence of a radio had no effect on any of those parts.
    • William C.
      • May 31, 1975
      • 6037
      Chances are you will find your flasher flopping around in the area where the radio would normally be, attached to the IP wiring harness.
      Bill Clupper #618
      • Michael S.
        • June 7, 2007
        • 82
        Thanks John and Bill for the response.
        Bill, you were right, I found the flasher dangling from the wiring harness behind where the radio would be if I had one in my car.
        I am really thankful that there is an NCRS technical discussion board to help out a newer member like me when I need help.
