Mystery Switch on 4 Speed Trans? - NCRS Discussion Boards
+ More Options
Posts
  • Carr C.
    • March 1, 2004
    • 86
    I'm are working on a 1973 454 Corvette with a 4 speed transmission. It has an electrical switch mounted in the 1-2 shift arm boss of the transmission side cover.
    The switch has 1 black wire running to it that runs up to the firewall and into the interior.
    Any ideas on what this is?
    Thanks in advance!
    • 11677
    Re: Mystery Switch on 4 Speed Trans?
    You sure it's the 1-2?
    I would suggest that it's the 3-4, and it's part of the TCS system.
    Patrick
    • Wayne M.
      • March 1, 1980
      • 6414
      The switch has 1 black wire running to it that runs up to the firewall and into the interior. Any ideas on what this is ?
      Carr (& Patrick) -- I'm not familiar with C3's, but I've seen a few Muncie side-covers with BOTH a switch on the 3-4 boss (like the '70-up 3952698 cover, AND another on an identical boss for the 1-2 shift. This latter cover has a unique cast part #, only 6 digits (like 3xxxxx). There was one on eBay a few weeks ago (should'a taken note).
      So there was a need (maybe not Corvette) for a signal off the 1-2 shift position.
      • Harmon C.
        • August 31, 1994
        • 3228
        Patrick
        I agree
        I had a 73 454 four speed and it had the TCS on the 3-4 and only was on in the 4 position.
        Lyle
        • Wayne M.
          • March 1, 1980
          • 6414
          (Revisit) Mystery Switch on 4 Speed Trans?
          The switch has 1 black wire running to it that runs up to the firewall and into the interior. Any ideas on what this is?
          Carr & others who responded to his post a few months back.
          From a recent eBay auction for some Muncie parts, including 2 sidecovers; the dirty 3952648 (switch on 3-4 shift arm) and another (clean) cover which I'd mentioned at the time, although I didn't have the part # or a pic back then. Shows here as 6-digit # 335308. This particular one does not have the 1-2 shift cast boss drilled, although I'd seen one with both 1-2 and 3-4 switches in place.
          Probably '70-up usage, and unlikely Corvette.
            • 43255
            Re: (Revisit) Mystery Switch on 4 Speed Trans?
            Wayne-----
            I think the cover with the 2 switch BOSSES, one equipped with the TCS switch and the other unmachined, may have been used on some 73 and/or 74 Corvettes. However, the cover with both bosses machined for switch installation I do not think was a Chevrolet piece. The casting number was a Chevrolet part number because the Muncie was manufactured by Chevrolet. However, it was also used on Buick, Pontiac, and Oldsmobile. I suspect that the cover with both bosses machined was used for one of these other carlines and in the 73-74 period. It may have had a non-Chevrolet finished part number or it may have had a Chevrolet part number which was not used on any Chevrolet model.
