Correct color speedometer gear - NCRS Discussion Boards
  • Robert M.
    • April 30, 1999
    • 415
    What is the correct color plastic gear for the trans and a 3.08 rear. Thanks
  • Harry S.
    • July 31, 2002
    • 5349
    Re: Correct color speedometer gear
    https://www.forums.ncrs.org/showthre...color&uid=7924
      • 43295
      Robert-----
      Assuming the tire size is as-original and the transmission is a 4 speed, and the car is a C2, the gear should be a "natural" (i.e. very light yellow) gear of 19 tooth count. GM #3987919.
      • Robert M.
        • April 30, 1999
        • 415
        Robert-----
        Thank you Joe and Harry
        • James W.
          • December 1, 1990
          • 2680
          What year of Corvette?
          James West
          • Robert M.
            • April 30, 1999
            • 415
            James, it is a 1967 with an M20 wide box and a 3.08 rear. I have 205-75R-15 radials on it. The tach appears to be dead on at speed bu the speedo is runing 10-12 mph slow.
            • Wayne M.
              • March 1, 1980
              • 6414
              Robert -- By tach "dead-on" at speed, let's assume a true 60mph, your tach should read about 2360-2400 rpm. Now you say the speedo reads 10-12% low; ie. reads 53-54 mph. Your 205-75 radials are probably only 1.5% less rolling circumference than the original 7.75's (ie. not much).
              Assuming that your tach and speedo are correctly calibrated, you may find you already have the red 21-tooth gear, instead of the 19-tooth neutral (light brown). This would explain just about all that you are experiencing. But if you find the 19-tooth gear in there, then you must be out of calibration, or you will require an external speedometer adaptor to increase the cable rotation; all other gears (blue, red, etc.) will slow the speedo cable.
