1967 RH outside mirror - NCRS Discussion Boards
  • Larry S.
    • March 11, 2007
    • 457
    There's a '67 outside rear view mirror on e-Bay for the RH side. It has the screw tightener in the same location as the LH mirror (on the right side or top side of the mirror looking at the mirror from the driver's seat). Is this correct? It would seem that the RH mirror would be a mirror image (no pun intended) of the LH mirror, with the mounting screw on the left side or top of the mirror when it's mounted.
    I'd love to have a RH mirror on my car since visibility is pretty limited with the top up. I assume this was an original option. I'm pretty new here, so forgive my ignorance.
  • William C.
    • May 31, 1975
    • 6037
    Re: 1967 RH outside mirror
    RH Mirror not available as a factory option on any 63-67 Corvette. Dealer (or owner) installed over the counter only.
    Bill Clupper #618
    • Larry S.
      • March 11, 2007
      • 457
      Thanks, William; I did not know that. Is the mirror I described a correct one (mounting screw placement)?
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1463
        Your logic makes sense.
        Not having seen this mirror, are you sure it is not just a LH mirror?
        H.a.N.D.
