I would appreciate it very much if someone can give me the ECL on a J50 power brake option with the L75 engine and no J65 metalic brakes for a 63 837 coupe with M20 4 speed and G81 posi rear axel. Was this option discribed as VACUME POWER BRAKES or POWER BRAKES on the build manifest? Thanks much! ....stan #19259
I need ECL for J50 w/L75 & no J65 on 63
Re: I need ECL for J50 w/L75 & no J65 on 63
Stan -- From Noland's Vol 2, page 124, the ECL code for J50 for Base engine or L75 or L76 with manual trans is "G".I would appreciate it very much if someone can give me the ECL on a J50 power brake option with the L75 engine and no J65 metalic brakes for a 63 837 coupe with M20 4 speed and G81 posi rear axel. Was this option discribed as VACUME POWER BRAKES or POWER BRAKES on the build manifest? Thanks much! ....stan #19259
So the line on the window sticker would read 2J50G VACUUM POWER BRAKES.
I'm not 100% sure on the "Vacuum" for 1963, although '64 thru '67s used this descriptive.- Top
- Top
