Powerglide Puke - NCRS Discussion Boards
Powerglide Puke
  • Mike M.
    • May 31, 1974
    • 8405
    Powerglide Puke
    try this trick if yer powerglide pukes ATF after sitting for extended periods. Start the engine in Neutral. Lubrication of the PG's inards is cut off when the lever is in Park. over a week or two of non-use, the ATF in the converter drains down and overfills the sump.When in Park, the converter will not fill and the ATF will be further areated and forced out the filler tube. It takes about 4 minutes to fill the torque converter , so leave the PG in Neutral during this time or yer nice garage floor will be pink. mike
  • Warren S.
    • April 30, 1987
    • 100
    Re: Powerglide Puke
    Mike,
    I've been using something similar to your suggestion. Quite a while back someone on this forum, I think it was Roy, suggested instead of putting the transmission in park and then killing the engine, put the transmission in neutral, then kill the engine and then put the transmission in park. I don't have an explanation as to why or how this works but it does and has eliminated the pool of ATF I was getting after my car set for weeks at a time. I know that this sounds far fetch, but it has been working for me.
    Warren
    67 red/red vert - 31 years
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11361
      Re: Powerglide Puke
      Great info, thanks guys!
      • Edward M.
        • November 1, 1985
        • 1922
        Re: Powerglide Puke
        OK, a great idea. Now all I have to do is figure out where neutral is. It's a work in progress, but it does go up and down the street now.
        • Roger W.
          • January 29, 2008
          • 571
          Re: Powerglide Puke
          This subject was discussed in "Cars & Parts" May 2008 issue. Eckler's Classic Chevy International www.classicchevy.com sells a one way valve (Pt. no. 19-28) that installs on the return transmission fluid line from the radiator. You probably don't want to put one of these valves on a car that will be judged.
          • Edward M.
            • November 1, 1985
            • 1922
            Re: Powerglide Puke
            Also be tought to put one on a Corvette since they did not have radiator cooling lines. I am going to add an aftermarket transmission cooler to my 56 rat rod.
            • Michael W.
              • July 31, 2006
              • 190
              Re: Powerglide Puke
              Great info! I have the same puke issue, my car in in storage with some other Dutch chapter members cars (like rob and sander) and they always make fun of my freshly rebuild but puking PG.
              I will test your advises!
              Mike
              Michael Westenberg
              #46144
              '65 rally red convertible + flip flop interior
              '99 torch red coupe + light oak interior
