Camshaft L68 427 - NCRS Discussion Boards
Camshaft L68 427
  • John V.
    • January 23, 2008
    • 4
    Camshaft L68 427
    I need help a cam spec for 427 Tri Power L68 I am rebuilding the engine and the cam need replacing
    • 43247
    Re: Camshaft L68 427
    John-----
    The cam was GM #3904359.
    lift---intake=0.461"
    lift---exhaust= 0.480
    intake duration @0.050"= 214 degrees
    exhaust duration @0.050"= 218 degrees
    lobe centerline= 115 degrees
    You can obtain a Crane-manufactured replacement of this cam (or, its rear journal grooved counterpart, GM #3883986) from GM under GM #12364055. This is a kit which includes lifters.
    • John V.
      • January 23, 2008
      • 4
      Thanks Joe That is the the wright spec I need Regards John
      • Clem Z.
        • January 1, 2006
        • 9427
        here are the complete specs. at .050 lift. duration 214/218, open/close at .050 lift (3) 37 intake, 49 (11) exhaust, lobe seperation 115, lift .461/.480
        • John V.
          • January 23, 2008
          • 4
          Thanks Clem Great Help
          Regards John
