1967 brake calipers - NCRS Discussion Boards
1967 brake calipers
  • Jeremy H.
    • January 1, 1999
    • 260
    1967 brake calipers
    What is the correct part numbers for 67 calipers? I have a GM parts book that shows : rear left outer #5462016, rear left inner #5461991, rear right inner #5461992, rear right outer #5462017, front left inner #5463158, front outer # 5457263, front right inner #5462045. Is this correct? Do they even judge this? It is not in the JM.
    Jeremy Hedges #31711
    • 43279
    Re: 1967 brake calipers
    Jeremy-----
    Those sound like finished part numbers for the caliper halves. They will appear nowhere on the calipers. 1967 used 2 different sets of calipers. Early used CASTING NUMBERS 5465952 and 5465954, front, and 5465902 and 5465905, rear. Later used CASTING NUMBERS 5452273 and 5452270, front, and 5452281 and 5452284, rear.
    I don't think that caliper casting numbers are currently a judged item.
    • Gerard F.
      • June 30, 2004
      • 3806
      Jeremy,
      Don't think they judge the numbers, just configuration and finish.
      Correct me if I'm wrong, guys.
      Jerry Fuccillo
