C2 Base Engine Manifold Vacuum - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 952
    I'm reading 21 in Hg on my 66 327/300 hp 4 speed engine. Engine was rebuilt about 30K miles ago. Vacuum is steady at 21 in.@ 600 rpm. I trust the vacuum gauge. Most of everything that I see posted on the base engine 4-speed says 17-19 in Hg at around 550-600 rpm.
    I never thought too much vacuum was a problem?
    Dave K.
    • 15706
    Re: C2 Base Engine Manifold Vacuum
    Higher idle speed yields higher manifold vacuum.
    I don't know what the AMA specs recommended for your car, but for '63 the 327/250-300 is 500 RPM in neutral for manual transmissions and IIRC 450-475 for Powerglide in Drive. At 500 in neutral with a manual trans typical vacuum is 18-19", so drop your idle speed down and see what it reads.
    The recommended idle speeds vary with year, and K-19 cars have a higher recommended idle speed than non-K-19.
    My rule of thumb for idle speed is "the lowest commensurate with acceptable idle quality", and "acceptable idle quality" will vary among individuals.
    I think the 250/300 HP idle speeds are reasonable, but I also think the 700 recommended for some SHP engines is unrealistically low.
    • Dave K.
      • November 1, 1999
      • 952
      Duke,
      It won't idle smoothly below 600 rpm. It surges about +/- 50 rpm below 600 rpm and vacuum surges.
        • 15706
        Yes, IIRC there was a previous discussion on the issue with no clear indication of a solution. If it won't idle below 600 just let it be.
        • Dave K.
          • November 1, 1999
          • 952
          Duke,
          That's my plan. However, this gives me little hot idle margin if I want to PV car. Specs call for 450-600 rpm for PV.
