R45 vs R45S for 1963 327 300hp - NCRS Discussion Boards
  • Stanley M.
    • January 31, 2007
    • 3
    My numbers matching car has AC 44N installed and they are black as my carb has been too rich and driven infrequently. I have resolved that and want to replace the plugs with AC 45. I have a new set of R45-S. Can I use those or do I need to have R45? I am concerned of course about the extended tip.
    • 15706
    Re: R45 vs R45S for 1963 327 300hp
    R45S are okay to use.
    • Dave S.
      • August 31, 1992
      • 2930
      Stanley,
      A 44N plug indicates you have a Big Block. 45, 45S or R45 will not fit a Big Block.
        • 15706
        Good point. The thread title says '63 327/300. Maybe he has the long awaited proof that you can use a 3/4-inch reach plug in a flat-top piston small block without busting something.
        For reference the C2 small block spark plug family is 14mm thread, 13/16" hex, 3/8-inch reach, gasketed seat.
        • Clem Z.
          • January 1, 2006
          • 9427
          since extended tip plugs see "fuel wash" which cools the plug i would use a R46 S.
          • Stanley M.
            • January 31, 2007
            • 3
            Motor according to NCRS Judge Roy Robinson is a 327 300hp so after looking at the posts, I'll stay with the R45 if that is a little hotter plug than the 44N. Does that work? I wanted something one step hotter.
            • Timothy B.
              • April 30, 1983
              • 5202
              Stanley,
              The R45 would be one step hotter then R44 and should work fine for your 300 HP car.
              • Michael H.
                • January 29, 2008
                • 7477
                If the engine over rich condition/problem has been corrected and the car is driven on the road occasionally, the R45's should work.
                The original heat range spark plug for that engine was indeed an AC-44. (not AC-R44)
                As others have mentioned, the 44N, or N series spark plugs, are long reach and were used in big blocks, not small block 327's.
                • Ken A.
                  • July 31, 1986
                  • 929
                  Plain 45's work better than R45's (if you can find them) cause R stands for "resistor".
                  • Stanley M.
                    • January 31, 2007
                    • 3
                    Thankyou very much.
