Replacement Tires for a 1966 Roadster - NCRS Discussion Boards
  • David J.
    • August 19, 2007
    • 65
    I am in the process of selecting new tires for my '66. It appears that the 205-75-15 is the tire most recommended. However, the choices in that size are rather limited. What are the drawbacks of using a 215-75 or 215-70. Any and all recommendations would be appreciated. Thanks.
  • Peter J.
    • September 30, 1994
    • 586
    Re: Replacement Tires for a 1966 Roadster
    David, I've used 215s with stock wheels on my -66 for about ten years without any problems.
      • 15706
      There is a ton of information in the archives. This subject has been hashed out almost as much at engine oil.
      • Larry S.
        • March 11, 2007
        • 457
        I really like the wider look of my 215s; no clearance problems whatsoever on my '67. They're Firestone redlines from Volunteer Corvette (free shipping!).
        • David J.
          • August 19, 2007
          • 65
          Thanks, Larry. I have really struggled trying to find a performance tire in the offerings today. Going to 215s really broadens the choices.
          • David J.
            • August 19, 2007
            • 65
            Thanks, Peter. As I mentioned to Larry, this really broadens my choice. I appreciated both of you sharing your thoughts.
            • Rick S.
              • January 1, 2003
              • 1203
              David,
              I would look at Diamondback as a good supplier of tires as they will do a modern tire with a sidewall of your choice.
              www.dbtires.com
              Rick
              • David J.
                • August 19, 2007
                • 65
                I checked out the site, Rick. Great suggestion. Thanks.
                • Dan A.
                  • May 31, 1974
                  • 1073
                  For those using 215's are they 215 70's or 215 75's?
