C3 defroster vacuum actuator - NCRS Discussion Boards
  • Kenneth K.
    • September 30, 1992
    • 118
    Does anyone know how to remove the vacuum actuator from the defroster door located in the heater box? I am hoping that I don't have to remove the heater box to get the vacuum actuator off. I uploaded a picture of the old actuator that is still attached to the heater box to show you which actuator I am talking about.
    The vacuum actuator is located under the dash on the drivers side. I had to take the center console off to get access to it. But I can't see how to disconnect the actuator from the defroster door lever.
    I uploaded a picture of the new actuator that I need to install. The lever has a hole near the end that is connected somehow to the defroster door lever. Is the actuator riveted on to the defroster door lever?
    Any help would be appriciated.
    Ken
  • D S.
    • March 1, 2005
    • 1551
    Re: C3 defroster vacuum actuator
    What, are you a contortionist? That is a good photo. I have the same dilemma. Had now 'cause I don't care to remove the box to get to that thing out.
    • Joseph H.
      • December 11, 2007
      • 159
      Ken,
      Did you ever figure this one out? I have the same issue and it looked impossible without removing the entire unit. My acuator actually works in one direction, but not the other. I will most likely leave it alone as I only drive the car with the top down on sunny days.
      J Hudec
      • Kenneth K.
        • 118
        Joe,
        I decided not to replace my actuator because of the difficulty in removing it.
        Ken
        • Paul L.
          • November 1, 2002
          • 1414
          I'm afraid ... this is the answer.
