1972 SB-timing tab finish - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    From an originality prespective was the timing tab on a 1972 small block painted engine orange or was it left unfinished? Or was it just partially painted?
    • 43246
    Re: 1972 SB-timing tab finish
    Jerome-----
    Generally, I believe they were painted with the engine and then the surface with the timing marks was "wiped". I'll bet there were more than a few which didn't get the "wipe", though.
      • 11659
      Like this:
      • Robert C.
        • December 1, 1993
        • 1153
        Most i've seen had been masked off half way down. With the tape removed after engine painting, leaving the timing marks natural.
        • Phil D.
          • January 17, 2008
          • 206
          Reviving an old thread, but just removed the paint from a 72 SB timing tab and it appears that it had some plating on it originally, possibly a zinc or galvanized finish. What was exposed was rusted but under the paint was mostly bright and shiny. Some of the underside appeared tarnished and grey but not rusted. Should I bead blast the whole thing and re-plate in zinc or something else before repainting or other suggestion?
          • Jerome P.
            • October 22, 2006
            • 607
            If other procedures to remove the rust did not produce the desired result, then lightly bead blast, replate, paint with engine and wipe paint off in area of timing marks. (It may be the finish of the bracket is just natural)
              • 11659
              I would try a chemical de-rusting or similar. Beadblasting will alter the finish, and even if replated may "dull" the apperance.
