'67 Voltage Regulator - NCRS Discussion Boards
  • Mark S.
    • October 22, 2006
    • 35
    Two questons for my '67 L79:
    1. I just put new mufflers on my car and I want to hear how they sound. My voltage regulator is being rebuilt by John Pirkle. Will my car start without a voltage regulator?
    2. My friend has a spare voltage regulator from his '68 L79 that he is willing to let me borrow. Will it work properly on my car?
    Thanks in Advance, Mark
  • Douglas L.
    • August 31, 2003
    • 302
    Re: '67 Voltage Regulator
    Mark,
    If you have a standard points ignition, you should be OK without the voltage regulator for a test run. If you have transistor ignition, I think I would avoid running without the regulator. The 68 voltage regulator will work - no problem.
    • Mark S.
      • October 22, 2006
      • 35
      Doug,
      Thank you for your response. I will ask my friend to borrow his spare. Kurt are you out there???
      • Kurt B.
        • July 31, 1996
        • 971
        Mark,
        Glad to hear the 68 voltage regulator will work for your car.
        Let me know when you want it and I will get it to you.
        Kurt
