Any Tricks for Reinstall of C2 Rear??? - NCRS Discussion Boards
  • Joel T.
    • April 30, 2005
    • 765
    Hi Guys;
    Well, I pulled the carrier out of the rear of my '63 today. Many thanks to the folks on this site who provided removal tips! It actually came out easier than I thought. The whole thing took like two hours!! The car is up on jack stands and I was able to remove the spring, rear struts and half shafts with no problem. I did not take the exhaust off the car. There was a bit of nudging required to get the old carrier down, around the pipes, but it found its way out.
    I'm trying to get the new carrier up there, around the exhaust pipes, without screwing up the gasket.. This is not easy! I've given up for today and figured that I would sit, have a brewski, and think about what to do/try next and ask you guys for any pointers you might be able to offer.
    My guess is that if I take the exhaust down, life would be easier because it seems that the biggest hassle is getting the yokes past the pipes.
    Anybody have a trick to get this done with the pipes still in place... or should I just face facts and haul the pipes down???
    Joel
    PS. I've taken T10's and Muncies down and put them back up while laying on my back on the floor using good old muscle power.... but I gotta say that rear carrier is HEAVY!!!
  • Chuck G.
    • May 31, 1982
    • 2036
    Re: Any Tricks for Reinstall of C2 Rear???
    I've had luck using a friend or two and a floor jack.
    TOUGH to bench press those cast iron parts when you get old.
    Chuck
    • Mike M.
      • May 31, 1974
      • 8397
      have a friend or two OPEN THE BREWSKIS while you re-install with a floor jack, good luck,mike
      • Joel T.
        • April 30, 2005
        • 765
        Guys;
        Amen on the bench pressing stuff.... used to be easier as I recall (way back when). Ahhh The price of maturity!!
        Thank goodness I have enough strength left today to crack open those pop-tops!
        Joel
        • Chuck G.
          • May 31, 1982
          • 2036
          I pulled the 4 speed Muncie trans out of my 63 last year.
          Got it out just fine. Did the fix, and....................
          TRIED and tried to get it back in myself. Just didn't have the strength to bench press it back in place. I had done it many times in the past.
          Had to "suck it up" and called 2 of my friends. Both came over. We had the trans up and in place in about 3 minutes.
          Chuck
