C1 fuel injection RH exhaust manifold - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 660
    Sorry to beat a dead horse all, but have searched the forum and archives a number of different ways to find out the correct casting number for a C1 fuel injection right hand manifold. Can anyone in the group verify the right number? Thanks.
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    B52 Pile it... If you would give the year and if you had an NCRS spec guide or an NCRS Judging Guide, you could answer that question yourself...
    • Keith R.
      • August 31, 2001
      • 660
      Re: C1 fuel injection RH exhaust manifold
      Thanks Dennis. I've read the JM guidance a number of times and I don't think that it reads clearly. It says, "3749965 - Left-Hand; 3750556 - Right Hand; and, 3732498 Right-hand ('58 FI possible)" So specifically, my question is, which casting number is correct for a 1960 FI right hand exhaust manifold, 3750556 or 3732498?
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
      • Dennis C.
        • January 1, 1984
        • 2409
        According to the NCRS Spec Guide - Right Hand:
        The '498 = Early 1958 FI (possible)
        The '556 = All Engines
        Of course, choke hole drilling/non drilling on FI must be considered as part of the package.
        Best, Dennis
        • Keith R.
          • August 31, 2001
          • 660
          Thanks mucho Dennis - '556 it is then. Still don't quite understand what year the '498s are found on other than 1958 FIs possibly.
          Best,
          Keith
          Keith MacRae
          NCRS #36692
          New Mexico Chapter
          1960 290HP FI
          • Dennis C.
            • January 1, 1984
            • 2409
            Yeah Keith, I'd head for a non drilled '556 (FI application) and be a happy camper. Of course, unless you are one lucky dude and have one in your possesion, finding an original is a tough, expensive nut to crack. I believe a pretty good one may be available in reproduction, but I would advise you have your hands on one before you lay down your frogskins...
            I'm sure if you can fly a B52, you can read between the lines...
            • Mike M.
              • May 31, 1974
              • 8389
              check out the junkyards for chevy trucks of the 57-60 variety. need to be a 1 1/2 ton or more critter to get the non-drillled for choke right hand 57 fi manifold. figure on about 500 frogs for an original unless your junkyard trip is successful.. the repo's are discernaby different than the originals.mike
