Which way should this bolt go....threaded end up or down?
I just went to install my spring and the threaded end is up(sticking past the nut about 1/2") and it hits on the diff housing. The first thought was that I'll just cut the threaded stub off and I'll be good. Then I thought that maybe the threaded end should be down....
Do the judges expect to see the threaded portion sticking through the bottom spring plate or should it just be the head of the bolt in the spring plate opening?
For what it's worth my bolt head isn't a hex head...it's just a round but flat head with I think a "W" in the center of it.
