I'm aware of the way you are supposed to bend the cotter pins on the lower ball joints so that the factory camber/caster tooling can be installed but is it also the same for the uppers?
I know this is probably a stupid question but the 1969 AIM shows how to bend the lowers as per "Detail A" but "Detail A" is only for the lower and not the upper ball joint so I was just wondering if the uppers gets bent the same as the lowers.
