69 alternator mystery - NCRS Discussion Boards
  • Mark A.
    • February 1, 1996
    • 299
    I took the alternator off my 69 435 hp coupe. It has a 6 spoke front cover. The stamp is 1100864. The 6 is very faint. I could not find this number listed anywhere. Also the number off the pulley is 3829387-AI. Would this be the correct pulley by chance? Does anyone know where this alternator and pulley could be from? Thank you for the help. Mark
    • 43295
    Re: 69 alternator mystery
    Mark-----
    I strongly suspect that the number is 1100884. If so, this is a 61 amp alternator that could have been used for your application. I can find no record of an alternator of GM #1100864 ever having existed.
    The GM #3829387 alternator pulley could have been used for your application IF the car does not have power steering.
    • Mark A.
      • February 1, 1996
      • 299
      Joe,
      I guess it could be an 8. It is very faint. The 4 next to it is also light, but not as bad. My car does not have power steering, so I believe the pulley is correct. Thanks for the reply, Mark
      • D S.
        • March 1, 2005
        • 1551
        Of the six or seven 1100884s I've personally seen every one had a slight space between the 1100 and 884 and the A in 61A is dropped slightly lower than the 61.
        • Donald S.
          • August 31, 1996
          • 186
          Here's a picture of my alternator off my November built '69 435.
          Don
