Please help with 350 block... - NCRS Discussion Boards
+ More Options
Posts
  • William V.
    • December 1, 1988
    • 399
    Can any help me identify where the 350 block and heads, that I removed from a 76 c3, came from. The engine was built as a 383 stroker. The block is 4 bolt main part number 3970010. The stamp pad has K1214TYC / 084126019.
    The head's (part number 333882) are closed chambered, screw in valve studs and 202 intake valves.
    Bill
  • Robert E.
    • April 1, 2004
    • 398
    Re: Please help with 350 block and head id.
    Hey Bill,
    According to the chevymania website, suffix code "TYC" belongs to:
    Code Year CID Vehicle HP RPO Trans Carb Comments
    TYC 75 350 Truck 145 Base Manual 2-Bbl C-10
    TYC 76 350 Truck 145 Base Manual 2-Bbl C-10
    TYC 78 350 Truck 165 LS-9 TH-350 4-Bbl C-20 & C-30, Van
    The heads are listed as:
    333882 350/400 70-80 1.94/1.50 76cc
    I hope this helps.
    Rob
    Bill
      Re: Please help with 350 block...
      It's a 350 built at McKinnon Industries, originally installed in a '78 Chevy Van built at Scarborough, Ontario.
