About the Drum Brakes on my 64 - NCRS Discussion Boards
  • Bud K.
    • July 31, 2005
    • 60
    The automatic adjustors for the drum brakes have a left and right hand side. BUT..... do they also have a front and rear difference due to the e-brake, or are they the same?
    Bud.
  • Joel T.
    • April 30, 2005
    • 765
    Re: About the Drum Brakes on my 64
    Bud;
    No difference front to back. Just make sure that you get the side to side correct. I picked up all new brake hardware from LI Corvette. The stuff was marked "L" and "R" which turned out to be confusing as I believe that represented the thread not the side... I kept all the old parts by each wheel as I did the job and put the adjusters in based upon the the thread of the old adjuster. Worked!
    Good luck,
    Joel
