C4 Build sheet locations - NCRS Discussion Boards
  • Richard C.
    Infrequent User
    • August 31, 1987
    • 7
    Help,
    Trying to locate my original build sheet for my 1985 #1518. I have some locations to search, but don't want to tear the car apart to find nothing. Any previous knowledge or tips would be greatly aprreciated.
    Rick
  • Robert C.
    • December 1, 1993
    • 1153
    Re: C4 Build sheet locations
    Look at inner bracket of the strut bar, folded up inside. Also behind the speedometer behind dash.
    • Joe C.
      • August 31, 1999
      • 4598
      Originally posted by Richard Capone (11910)
      Help,
      Rick
      You can get an exact duplicate from the NCM in Bowling Green, KY.
      I don't remember hunting for mine. I seem to remember that it was just "there" in all of the papers I recieved when I took delivery of the car. Who knows, it might even have been on the floor, somewhere. At the time, I wouldn't have known what it was anyway, but I decided at that time (serendipitously) to keep everything relating to the car that I found. Heck, I even kept the carbon copies of the certified checks I paid for the car with!
      Bottom line is: I don't think that there is a secret hiding place, like on the tank, or under the dash, as with some of the older models. So, if the original owner didn't retrieve it then, its long gone.
      • Lyndon S.
        • April 30, 1988
        • 1027
        I have found them tucked up in the strut bar also.
        • Tom H.
          • December 1, 1993
          • 3440
          Take the rear license plate off and peek inside behind the right tail light. You will probably see it there, on the tank. They are usually pinched in there pretty good. I'd order the duplicate from the museum.
          Tom Hendricks
          Proud Member NCRS #23758
          NCM Founding Member # 1143
          • Richard C.
            Infrequent User
            • August 31, 1987
            • 7
            I don't know exactly where the strut bar is. Can you guide me to it.
            Thanks.
            • Richard C.
              Infrequent User
              • August 31, 1987
              • 7
              Thanks so far to all who have replied. As soon as I locate it, I'll post it's location.
              Thanks, Rick
              • Pat M.
                • April 1, 2006
                • 1582
                On my 96 a build sheet is on top of the gas tank, and I saw and photographed it in the manner Tom suggested.
                • Tom S.
                  • March 1, 2004
                  • 1087
                  Top front of the fuel tank on an 88 !
                  • Eric J.
                    • March 1, 1980
                    • 771
                    Best bet is to order one from the Museum. Also order the dealer invoice from GM. Is your SPI under the center console lid? That has all the RPOs on the car. C4s are easy to confirm options on. Eric
                    • Peter M.
                      • April 8, 2007
                      • 570
                      Thanks.
                      So, as Rick asked, "Where is the strut bar?"
                      • Joel A.
                        • September 30, 1997
                        • 214
                        I found one on my '85 on the driver side, top of the fuel tank. I saw it while replacing the fuel pump several years ago. Didn't try to remove it, as I did get several copies from the NCM.
                        Joel Adams
                        1974 Coupe
                        1985 Coupe
                        "I know the voices aren't real...but sometimes they have some really kewl ideas...."
                          • 11692
                          Right underneath your rear differential.
                          • Floyd B.
                            • November 1, 2002
                            • 1051
                            Yep. Mine is there too but it is laid flat on top of the tank and the wide black fuel tank strap goes right down the middle of it. The only way I could ever remove it w/o destroying it in the process would be to unstrap the fuel tank. I haven't yet ordered a duplicate from the NCM ($45) because I can't imagine what information it's going to provide that isn't already on the SPI label in the storage compartment.
                            "Drive it like you stole it"
                            • Lyndon S.
                              • April 30, 1988
                              • 1027
                              Just look all under the rear of the car, when I worked at a Chevrolet dealership in the early eighties they could usually be found under the cars in all the suspension components and exhaust.
