hose clamp tool - NCRS Discussion Boards
hose clamp tool
  • Walt W.
    • November 1, 1998
    • 92
    hose clamp tool
    A friend showed me a really neat tool used to remove or install GM hose clamps. It looks like a pair of plyers with a hole drilled in the center of the gripping teeth which prevent the clamp fromm slipping off the tool. He can't remember where he bought it. anyone know who sells these??
    Walt Weems
    • 43246
    Re: hose clamp tool
    Walt Weems
    Walt-----
    I assume you're talking about the pliers for corbin-style hose clamps. These used to be VERY common in mechanics' tool boxes. They were just a standard-type set of pliers with the grooves to retain the ends of the clamps. I haven't seen this type in years although they may still be available somewhere. The style that I know is available looks more like snap ring pliers. It's manufactured by Lisle or KD Tools (or, maybe both). I've seen these in Sears and other tool stores. They're not very expensive---about 20 bucks, as I recall.
    • Dennis O.
      • December 1, 1988
      • 438
      Re: hose clamp tool
      I made my own with a set of the right size "American made" pair of pliers and a grinder. Less than $20.00 as well.
      I just read this again; "a pair of pliers"? Sounds funny. Oh well, there is also a "pair of pants".
      • John S.
        • February 1, 2003
        • 78
        Re: hose clamp tool
        Walt..look in flea markets that is where i found mine..seller was glad to sell it for 2 dollars as not too munc demand for them.. ps i guess i am too old for the new forum i do not like it as well...John
        • Joe R.
          • July 31, 1994
          • 287
          Re: hose clamp tool
          Walt, I got mine at NAPA. It's made by K-D tools. The business ends are adjustable to grip the clamps at different angles. Works great. About $22.
          Joe
          • Rick S.
            • January 1, 2003
            • 1203
            Re: hose clamp tool
            I bought mine about 5 years ago at Carlisle. Many vendors had them for sale.
              Re: hose clamp tool
              K-D #429 - VERY handy tool, with adjustable ends on the jaws - makes Corbin clamps a piece of cake.
              • Walt W.
                • November 1, 1998
                • 92
                Re: hose clamp tool
                Thanks for all of the feedback. The local NAPA has the K-D 429 in stock. I'll get it tomarrow.
                Walt Weems
                • Jeffrey S.
                  • May 31, 1988
                  • 1890
                  Re: hose clamp tool
                  John:
                  I may be mistaken but the tool you pictured is not for Corbin clamps but for small band clamps like the ones used on fuel lines. I have this tool and the spring clamp tool. If I am wrong I apologise.
                  Jeff
                  • Bernard M.
                    • August 31, 1994
                    • 341
                    Re: hose clamp tool
                    Sears sells them. I've seen them at many tool vendors displaying at swap meets.
                    • David D.
                      • January 1, 2005
                      • 416
                      Re: hose clamp tool
                      Walt,
                      Where ever you get them at, just make sure the heads 'swivel' makes for much easier removal/application in tight spots....
                      Some even come with a couple different swivel heads, for different size corbin clamps.....
                      Good Luck,
                      David
                      • Michael M.
                        • November 1, 2001
                        • 411
                        Re: hose clamp tool
                        Originally posted by Jeffrey Salz (13182)
                        John:
                        Jeff
                        I have the same tool as John. Mine came from Sears. They were listed for the wire ring clamps. The ends swivel and also will lock compressed. Maybe they will work on others as well.
                          Re: hose clamp tool
                          John:
                          Jeff
                          Jeff -
                          When I bought it years ago, it was labeled "Corbin Clamp Pliers", although it would probably work fine on band clamps too; in production, we used Apex duckbill pliers with the ends of the jaws heated and bent about 15* for the band clamps.
                          • Walt W.
                            • November 1, 1998
                            • 92
                            Re: hose clamp tool
                            I bought mine yesterday at Sears. They call them Hose Clamp Plyers. Appear the same as K-D 429. they are Craftsman and Cost $ 9.99 with
                            a lifetime replacement warranty. Not Bad !!!
                            Walt Weems
                            • Bruce B.
                              • May 31, 1996
                              • 2930
                              Re: hose clamp tool
                              MAC Tools has a Corbin clamp tool which is like the ones pictured except it has a cable that goes to a set of remote jaws that are positioned on the clamp ends. Then you squeeze the pliers (which are connected to the jaws via the cable) and the clamp is free. A fantastic tool since positioning the pliers on the clamp which is sometimes difficult, is not necessary. I borrowed a set from my tool guy, expensive but excellent design.
                              Bruce B.
