06 Z06 Shifter Rattle - NCRS Discussion Boards
  • Peter K.
    • January 1, 1999
    • 117
    Does anybody know if GM has figured out why some of the Z06 shifters in the 06 model year rattle as you accelerate ? and If so, do you know what the remedy is?
    My dealer wasn't sure...
    Thanks in advance!
  • Rich G.
    • August 31, 2002
    • 1406
    Re: 06 Z06 Shifter Rattle
    There's been a lot of talk about this on CF and ZO6vette.com. I can't say I ever heard an answer. My 07 does it, but only if my hand is is on the shifter.
    Rich
      • 15640
      There is a TSB for this "comment," but it may or may not pertain to your car. If you search on Corvette Forum in the C6 Z06 section on the subject "shifter rattle" you may find the text of the TSB so you can decide for yourself if your car is covered. I know they are replacing some shifters under warrantee with 2008 shifters. As to whether that cures the rattle .... well that is another story.
      • Tom S.
        • March 1, 2004
        • 1087
        I don't know about the ZO6 rattle, but i'm sure the new ZR-1 will ratttle!! If nothing else your teeth!! I wonder if the dealers will allow test drives?
        • Jim B.
          • July 31, 2002
          • 146
          I have heard this in the CF threads but like the needle bearing issue and the loose axel nut issue, I have found none of these with my 2007 Z06. It has just been a great car. No issues at all.
          Jim Boudreaux
          LA Chapter, NCRS
          _____________________________
          1968 British Green Convertible 327/350HP Original Owner
          2002 Z06 Black on Black Original Owner
          2007 Z06 Velocity Yellow w/Black/Titainium Original Owner
