56 Corvette balancer - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1922
    It appears that there are two different types of harmonic balancers for 56 Chevy engines. One type has the pulley riveted to it, and the other type has a bolt on pulley.
    What is the correct application for the two different types of balancers?
    • 43274
    Re: 56 Corvette balancer
    Ed-----
    From what I can tell, there were FOUR different balancers used for 1956 Chevrolet engines:
    1956 265 cid except 2X4 or A/C----GM #3711319--riveted pulley+balancer;
    1956 265 cid with A/C----GM #3719629---riveted 2 groove pulley+balancer;
    1956 265 cid with 2X4---GM #3712763--riveted pulley+balancer; also used for Corvette;
    1956 265 cid with 1 X 4 Corvette-only---GM #3717206---I don't know the configuration of this unit
    • Edward M.
      • November 1, 1985
      • 1922
      Ed-----
      Thanks Joe. Now, any idea how to tell the difference between 3711319 and 3712763? Deep groove pulley perhaps?
      • Mike M.
        • May 31, 1974
        • 8408
        i'm guess the 319 is a shallow groove and the other a deep groove. mike
          • 43274
          Ed-----
          Technically, it's the width of the groove. However, a wider groove also makes for a deeper groove. The GM #3711319 has a pulley with 3/8" wide groove; the GM #3712763 has a 1/2" wide groove.
          • Roy B.
            • February 1, 1975
            • 7044
            56 is the same as a 55 riveted pulley and not a deep belt design
