C3 Power Window Motor Help - NCRS Discussion Boards
+ More Options
Posts
  • Dennis R.
    Infrequent User
    • April 30, 2001
    • 13
    I Have An 80 Power Window Question--the Motor Stopped All The Way Down. I Can Hear The Motor Click When I Press "down", But Nothing Happens (no Click, Nothing) When Pressed For "up". I Get 12 Volts On Both The Blue To Ground And Brown To Ground With The Wires Disconnected From The Motor. I Have Continuity On Both The Blue And Brown Wires, Showing I Do Not Have A Broken Wire.
    From This, I Thought That The Motor Must Be Bad. I Bought A New Motor. It Does The Exact Same Thing--goes Fine In One Direction But Does Not Work In The Other Direction.
    Please Help--at This Point, I Am Really Confused.
    • 43259
    Re: C3 Power Window Motor Help
    Dennis-----
    Power windows are certainly not an area of expertise for me. However, I think I might suspect a problem with the power window switch. It's still available from GM under GM #1725109 but it's a bit expensive at about 65 bucks, GM list.
    • Dennis R.
      Infrequent User
      • April 30, 2001
      • 13
      Joe--I thought the same thing, so I installed a new switch. I get 12 volts on each wire when in the up or down position--could it be 2 bad motors?
        • 43259
        Dennis----
        2 bad motors seems very unlikely to me. There may be other components in that system that are at fault.
        • Joe T.
          • October 25, 2006
          • 304
          In my humble opnion:
          can you tes or does the motor (either one) work correctly out of the car?
          can you test it or them separately on a bench with just leads from a 12 volt source?
          regards,,,joe
