Need high hp harmonic balancer - NCRS Discussion Boards
  • Tom O.
    • October 23, 2006
    • 28
    Re: Need high hp harmonic balancer
    I am still looking for the high horsepower harminic balancer for a 283 in case someone finds one.
    Tom
    • Brad K.
      • August 31, 1990
      • 414
      Tom....Look at Paragon Reproductions V.32 2007 catalog, page 16. Their version is priced @ $245. With all the different definitions currently in the mix......this one comes closest to meeting the standard. Call Marilyn & Dave Heitzman (currently writing the updated 58-60 Judging Guide) marilynheitzman@msn.com
      They can give you their definition and opinion on this balancer.
      Good Luck!
      • Tom O.
        • October 23, 2006
        • 28
        #18
        Good Luck!
        Will do.
        Thank you!
        • James A.
          • July 31, 2003
          • 36
          #19
          Tom, I've also been looking for an original for some time. Here are a couple of photos of an original 1961 high hp balancer. I've found several with the holes drilled, but it is my understanding that the correct balancer does not have the holes drilled through, only the balance holes. The balancer in the photos shows this.
          • Tom O.
            • October 23, 2006
            • 28
            #20
            James,
            Thank you very much for the pictures and the information. I have added both to my file.
            FYI, I took Brad's advice and wrote to Marilyn and Dave Heitzman to ask their opinion of the balancer that Paragon sells. I will be out of town starting tomorrow but will let the Discussion Board know what their reply is next week.
            Thanks again to everyone for their help . . . and does anyone have the pulley that bolts to the balancer??
            Tom
              • 43242
              #21
              Originally posted by Tom Orashan (46433)
              James,
              Tom
              Tom----
              The pulley was GM #3756328. It's been discontinued for a long time. However, I believe it's available in reproduction.
              Last edited by Joe L.; April 23, 2008, 05:36 PM. Reason: change "9" to a "7" in part number
              • Cecil L.
                • May 31, 1980
                • 449
                #22
                Is 3764318 the casting number or the part number? This one of two that I have and both are cast 3753066 or 3758066...kind of hard to read (disregard the number written on the balancer, it's wrong). There is also a numeral 8 on the inner spoke on the backside below the casting number and another character which looks like a manufacturers emblem of some sort.
                • Cecil L.
                  • May 31, 1980
                  • 449
                  #23
                  Another thing I noticed is that the holes on the outer ring of the original line up exactly opposite the pulley bolt holes on the hub spokes whereas the repros made from the 350 balancer have the holes a few degrees out of alignment...probably due to the post 68 timing mark re-alignment . See the Damper Dudes repro pics on my previous post.
                  • Loren L.
                    • April 30, 1976
                    • 4104
                    #24
                    3764318 is the part #; any balancer that is presented to you that has holes in the outer ring IS INCORRECT. I'm not about to remove mine to measure it, but I recall that the diameter is SLIGHTLY more than 6"
                    • Gary H.
                      Infrequent User
                      • September 30, 1990
                      • 25
                      #25
                      Hi Guys. I have one identical to Cecil's except no holes on the outer perimeter. Casting number appears same as Cecil's also (bolt hole drilled in middle of cast number obscures couple digits). Anybody know correct application? Thanks, Gary
                      • Joe M.
                        • February 1, 2005
                        • 590
                        #26
                        What is the depth of the center ring/outer ring as measued inside one of the spokes?
                        • Gary H.
                          Infrequent User
                          • 25
                          #27
                          Center ring is 1 1/4. Outer ring is 1 1/8. Center ring protrudes out about 1/16 at both front and back.
                          • Richard L.
                            • December 1, 1994
                            • 43
                            #28
                            Can you post pictures?
                            • Gary H.
                              Infrequent User
                              • 25
                              #29
                              • Gary H.
                                Infrequent User
                                • 25
                                #30
