Just when I think I am finished it pulls me back in.
I have a 265 engine for my '56 that was completly rebuilt about 4 years ago and I just installed it this winter. It is not oiling the right side head rockers and push rods. The left head oils fine. The oil pressure to the guage reads good. I know that the cam must have a groove in the rear and the builder on the other side of the country is checking his records to be sure that the correct cam was installed. Before I remove the engine and tear into it, is there anything else I need to look for? I have the correct distributor with the flat area on the shaft, but should it be indexed (turned) a certain direction? Could the plug on the right side oil galley under the timing chain cover be missing and cause loss of oil pressure on that side? Any suggestions would be greatly appreciated.
Steve #28428
I have a 265 engine for my '56 that was completly rebuilt about 4 years ago and I just installed it this winter. It is not oiling the right side head rockers and push rods. The left head oils fine. The oil pressure to the guage reads good. I know that the cam must have a groove in the rear and the builder on the other side of the country is checking his records to be sure that the correct cam was installed. Before I remove the engine and tear into it, is there anything else I need to look for? I have the correct distributor with the flat area on the shaft, but should it be indexed (turned) a certain direction? Could the plug on the right side oil galley under the timing chain cover be missing and cause loss of oil pressure on that side? Any suggestions would be greatly appreciated. Steve #28428
Have you run the engine to find this out or just priming to start?
