1958 early style hood catch - NCRS Discussion Boards
  • Sander B.
    • March 1, 2005
    • 499
    below i have a picture of 2 types of the hood catch
    the car has the early style cable supports
    i believe the left one on the picture is the correct one for
    the early style am i right ??
  • Joseph K.
    Infrequent User
    • May 31, 1988
    • 9
    Re: 1958 early style hood catch
    I found that the one like that on the right cannot be used with the early cable holder unless the hole for the end of the cable is moved inboard. The one on the left looks as if it will work without modification.
    • Donald S.
      • July 31, 1983
      • 3
      Joseph is right provided the correct 58 cable bracket is
      used as shown in the attached photo taken from my 58.
      • J O.
        • August 31, 1987
        • 19
        i believe the one on the left is correct for the early's. although i'm not sure where the cut-off is for early -mid-.. my car is a march '58 car and has the hood catch pictured on the left..
        hope this helps.
        john
        • Gord H.
          • March 10, 2008
          • 30
          My april 15th car has the one on the right.original to the car.
          • Sander B.
            • March 1, 2005
            • 499
            the ones on my car are for a februari car the short type should be correct because of the early cable holders i have
            i think they put one replacement (the long one) on it some time
            so i guess the change over was somewhere end march begin april ?
            • Donald S.
              • July 31, 1983
              • 3
              Interesting discussion. The build date on my car is January 2 or 3, 1958.
              The April - March time frame for the hood latch change over is about
              the time the hood support was moved from the passenger side to the
              driver side as I understand it.
              • Gord H.
                • March 10, 2008
                • 30
                My other 58 45XX feb 25th build date.has the hood holder on the passenger side.but had a change of hood catch to repo later style.had been made into 59-60 style.
                • Sander B.
                  • March 1, 2005
                  • 499
                  my car is from 25 feb and has the hood support also on the passenger side
