66 shock paint color? - NCRS Discussion Boards
  • Thomas N.
    • June 30, 1998
    • 45
    I am purchasing some AC delco replacement black shocks and want to paint them the correct gray color. Is there any close to original gray in a rattle can or a color I can have my local paint guy mix up?
  • Gary N.
    • August 31, 1986
    • 118
    Re: 66 shock paint color?
    I believe that Long Island Corvette sell a rattle can that they refer to as Shock gray. I used it and it looks good.
    Gary Nyland
    1966 Black Corvette Air Coupe
    2014 Black Z-51, 3LT Coupe
    1955 Black Chevy Belair Gasser
    1955 Nomad
    • Larry M.
      • January 1, 1992
      • 2688
      Tom:
      Both Paragon and Quanta also carry the correct shock absorber gray paint. Part number #2682 from Paragon and #0703 from Quanta for spray cans.
      Just about any of the larger Corvette parts suppliers should have what you need.
      Larry
      • John M.
        • January 1, 2000
        • 175
        The Krylon and Plasticoat NEW FORD GRAY are my color of choice for shocks, I know the question was what color to mix.....Thanks John Meissinger
          • 43211
          Thomas----
          I think any of the suggested paints will work fine. The original shock paint was not a "precise" sort of color; it varied.
          In military procurement, every nuance of detail for a procured item is tied down "six ways from Sunday". For example, the military has a huge specification chart for colors and each is defined by a 5 digit code. When a 5 digit code for color of a part is specified, the part has to meet the EXACT specifications for that 5 digit code.
          GM didn't do anything like that for shocks. What was the GM color spec for these shocks? They were to be finished in "gray". Now, that leaves a very WIDE choice of shades.
          • Brian M.
            • February 1, 1997
            • 1838
            I've used Krylon "smoke" color with no deductions
