C4 License Plate bolts? - NCRS Discussion Boards
  • Peter M.
    • April 8, 2007
    • 570
    What are the correct license plate bolts for a 1986 Corvette? Can you get these at any Chevy dealership?
  • Chris B.
    • August 11, 2010
    • 14
    Re: C4 License Plate bolts?
    Pete,
    Resurrecting an old post here, but the '84 - '86 JM says Torx heads for the front plate filler are correct. Mine has cross recessed there and appear stock so this may have been a running change, as I know my '91 that I bought new had Torx T15 there at the underside of the filler plate (a trick to get to and re-install).
    The rears seemed to be standard zinc plated cross head? FWIW there, I seem to recall that my '91 came with a "USA 1" black rear plate surround/holder.
    • George C.
      • December 1, 1988
      • 583
      Here's a pic of bolts for the 91-96's with a pic of the one of the front (factory plate filler) license plate bolts.
      • George C.
        • December 1, 1988
        • 583
        Here's a pic of the 84-90 Corvette license plate bolts. I had to do some digging. Hope these pic's help. 2 per bag. GM part # 14018850
        • Pat M.
          • April 1, 2006
          • 1588
          Originally posted by George Claery (13881)
          Here's a pic of bolts for the 91-96's with a pic of the one of the front license plate bolts.
          Yup. That's what I've got on my 96.
          • George C.
            • December 1, 1988
            • 583
            All 1991-1996 Corvettes (including ZR-1)came from the factory with the USA 1 rear license plate frame. The state plate slipped in sideways in frame held with the 4 torx style bolts shown in above posts. Not the standard car style. Part number on the rear frame is GM part number# 10146492. Not sure if license plate frame is still available from GM.
              • 43290
              George-----
              Unfortunately, GM #14018850 was never a SERVICE-available part number. It was, apparently, the part number of the PRODUCTION-only SET of screws supplied in the car. It's very possible that the single screws were available in SERVICE, though. However, I have not been able to confirm a part number for said screws.
              • George C.
                • December 1, 1988
                • 583
                Well it's late but I'm still up. I found something else relating to C4's. Sitting in my store room all these years. This was a shipping cover for the rear license plate from Bowling Green on the Corvette. Fits the 84-90 Corvette rear bumper.
                  • 43290
                  George------
                  GM #10146492 was once available from GM but it was discontinued several years ago.
                  • Tom H.
                    • December 1, 1993
                    • 3440
                    All 1991-1996 Corvettes (including ZR-1)came from the factory with the USA 1 rear license plate frame. .
                    I do not have the part number, but the ZR1 rear filler was a totally different part. It was larger to fill the larger spot in the wider rear bumper. The plate dropped in from the top center and didn't slide in from the side on the ZR1 unit, either.
                    Tom Hendricks
                    Proud Member NCRS #23758
                    NCM Founding Member # 1143
                    • Chris B.
                      • August 11, 2010
                      • 14
                      Interesting. There is quite a hole back there without any plate on and BG must have figured that would keep allot of crap out of the rear tub/tank area during shipment on the transporter.
                      I'd never seen this before. Thanks for posting.
                      • George C.
                        • December 1, 1988
                        • 583
                        opps, Thought it was the same due to U.S. license
                        plate size.Thanks Tom. LOL
                        • Peter M.
                          • April 8, 2007
                          • 570
                          Originally posted by Chris Brzon (52012)
                          Pete,
                          Chris - Thanks. But I have long since picked the correct license plate bolts up at Corvette Central. I have had them judged three times now without any problems.
                          • Tom H.
                            • December 1, 1993
                            • 3440
                            Here's the 91 to 96 #15 torx screw supplied with new Corvette back in the day !
                            Tom Hendricks
                              • 43290
                              Tom-----
                              It was GM #16509671. It was discontinued without supercession several years ago. If one needed one, one would be hard-pressed to find one.
