1967 Master Cylinder - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    On an original 67 MC how many areas are unpainted? Is it three, being the machined areas where the two brake lines attached and the flat spot where the "DC" is stamped? Thanks.
    • 43290
    Re: 1967 Master Cylinder
    Kirk-----
    Of the externally visible areas, the machined bosses surrounding the brake line fittings and the machined area on the front where the broadcast code is stamped are, indeed, the only unpainted areas.
