61 Splash shield location - NCRS Discussion Boards
  • Terry T.
    Infrequent User
    • July 31, 1999
    • 5
    I need some help. I can't locate where the splash shields fit on my frame. It appears that the old holes have been sealed over. Any help?
  • Las K.
    • July 31, 2006
    • 96
    Re: 61 Splash shield location
    wish my digital camera was working, but here goes, both sides are the same dimensions. From the frame extension to the body(where you have the body mount bolt) measure forward 1 1/4", and draw a vertical line. On that line, you have 2 hoes with the following centerlines. From the bottom of the frame, the first hole is 5/8" and the second hole is 1 5/8".
    Mine doesn't appear to be tampered with and both shields do fit.
    • Terry T.
      Infrequent User
      • July 31, 1999
      • 5
      I'll give it a try, thanks
      • Las K.
        • July 31, 2006
        • 96
        there is another hole forward on the drivers side, but you can scribe that one after a fit check. It's about 9-10" from the others.
        Good luck
        • Dennis C.
          NCRS Past Judging Chairman
          • December 31, 1983
          • 2409
          Install the shields. Remove the paint in the area the frame bolts want to go. At that point, the "picture" of where they were should become quite clear... DC
