I just got back from a show here which I had to drive about 75 miles each way. On the way to the show the car acted great.
On the way back as I quickly accelerated away from a toll booth the car lurched and bucked until I pushed in the clutch. I revved it slightly and let out the clutch and smoothly accelerated with no problem. As I got up to speed and tried to accelerate the car repeated this pattern at speeeds of 60 to 70 miles an hour (ie seemed to cut out) until I pushed in the clutch which reduced speed and smoothly accelerated and kept my speed down.
It had about 1/8 of a tank so I stopped for gas (V-power Shell prem.) but the problem remained in various degrees the rest of the way home. Sometime it would act like it wasn't present at all then I would accelerate abruptly from 60 and it would cut out and lurch until I brought the speed down. As I said the car was running very well. Also the distributor was recurved by Lars which had the car running great. I say this because I don't think it has anything to do with timing or distributor.
Any ideas?
Any ideas?
