66 manual tranny R & R ?'s - NCRS Discussion Boards
  • Thomas N.
    • June 30, 1998
    • 45
    66 327-manual full out the rear exhaust. Do you need the remove the exhaust to r & r the trans? Is there enough room to slide the trans back to do a clutch? Is it best to remove the shifter and linkage? Any tips or suggestions? Thanks Tommy
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: 66 manual tranny R & R ?'s
    No Need to remove the exhaust, you will need to remove the shifter and linkage.
    H. a. G. D.
    • William C.
      • May 31, 1975
      • 6037
      depending on the particular frame you may have to loosen the exhaust at the manifolds and also the center crossmember as it is not unheard for the engine to have to be lowered slightly to allow the bellhousing to be dropped to allow the clutch replacement.
      Bill Clupper #618
      • Mike M.
        • September 30, 1999
        • 710
        Take the ignition shielding off the distributor and remove the cap it may hit the firewall and crack.
