1966 427 390 wire - NCRS Discussion Boards
1966 427 390 wire
  • Tony C.
    • February 29, 2008
    • 117
    1966 427 390 wire
    Is the wire on the bottom of the ballast resistor to the ignition switch pink or green?
    Thanks Tony
  • William C.
    • May 31, 1975
    • 6037
    Re: 1966 427 390 wire
    Pink, at least per the wiring diagram in the assembly manual. That circuit was generally always pink or black with pink stripe(s)
    Bill Clupper #618
    • Tony C.
      • February 29, 2008
      • 117
      Where can I buy the pink wire for the ballast resistor. I looked around with no luck.
      Tony
      • William C.
        • May 31, 1975
        • 6037
        Which of the wires are you looking for? Both ends of the ballast resistor connect to wires that are part of the engine or IP wiring harnesses
        Bill Clupper #618
        • Tony C.
          • February 29, 2008
          • 117
          I need the wire that goes from the ballast resistor to the ignition switch.
          • Douglas L.
            • August 31, 2003
            • 299
            Tony,
            I found it a hard wire to exactly match. I got ahold of an old Corvette wiring harness and cut that wire out of it.
