Shock Application?? - NCRS Discussion Boards
Shock Application??
  • Daniel E.
    • April 30, 2005
    • 145
    Shock Application??
    Will the following shocks work for a C2? They have the correct appearance unlike current GM replacements.
    • 1154088 front
    • 1154090 rear
    Daniel
    • 43289
    Re: Shock Application??
    • 1154088 front
    • 1154090 rear
    Daniel
    Daniel------
    I can't find an application for them. It's possible they are for a 63-82 Corvette application, though. They are not a PRODUCTION-equivalent shock, however. I think that they are from a series of Delco aftermarket or Goodwrench/Target shocks. If they are dimensionally and configuration-wise the same as 63-82 Corvette shocks and they have the same piston travel, they should work on a Corvette. The valving might not be optimum, though.
