I was helping a friend get his 65 big block started yesterday. The starter would not engage and we found the part of the block broken off. Specifically, the outboard portion of the block where bolt goes up into the block is broken off. The piece that broke off was laying on the floor. After a phone call to a local shop we were told that this has happened before with 396 blocks and broken piece can be welded back on once the engine is pulled. My question is, has anyone heard of this problem before and is there another fix besides pulling the motor. Thanks in advance for any help.
396 Broken Block
Re: 396 Broken Block
Yes, not uncommon, no-cannot fix without having the bare block out of the car to the best of my knowledge..Bill Clupper #618- Top
I was helping a friend get his 65 big block started yesterday. The starter would not engage and we found the part of the block broken off. Specifically, the outboard portion of the block where bolt goes up into the block is broken off. The piece that broke off was laying on the floor. After a phone call to a local shop we were told that this has happened before with 396 blocks and broken piece can be welded back on once the engine is pulled. My question is, has anyone heard of this problem before and is there another fix besides pulling the motor. Thanks in advance for any help.- Top
Hello;
After the block repair(which experience shows will require removal) check for the correct starter bolts, that achieve proper torque before bottoming, and also a starter bracket.
Hope that helps.
RayAnd when you get the choice to sit it out or dance
I hope you dance
- Top
Hello,
I remember seeing on "The Last Sting Ray" that the Nabors brothers had to have that same piece welded on the original block due to it being damaged in shipping to them. It did not seem to harm that car. I also believe that the correct tapered / knurled starter bolts correctly torqued with the correct side support bracket, and correct initial (Base) ignition timing are a great place to start in stopping this from happening again. Not knowing what distributor you are currently running, it would also a good idea to make sure the advance weights are not stuck in the advance position. Hope this helps!
Bill- Top
I know that is one sick feeling on a matching numbers block.
I dealt with this on my 69 L68. Only I didn't locate the broken piece. I was able to repair it with the engine in the car. I used a steel coupling nut that I cut in half lengthwise and filed to match block. I placed a bolt in the exposed threads on the block and then placed the half coupling nut over the bolt to line up the threads.
I placed an insulating welding blanket between the block/bellhousing and the firewall.
I was concerned about cracking the cast iron from uneven heating. Since I couldn't start the engine to warm the block, I used a heat lamp overnight. Even with that, I preheated the area with the torch and brazed the coupling nut onto the block from the top down on both sides. The the starter bolts pulled up snug and I haven't had any problems with it since and that was about 5 years ago.- Top
