Fuel Tank Detail - NCRS Discussion Boards
Fuel Tank Detail
  • Tom L.
    • May 7, 2007
    • 438
    Fuel Tank Detail
    Regarding a '70, I have four questions related to the fuel tank.
    1) Does anyone make the small tower clamps for the vent line? I threw my old line out, with the clamp on it, assuming that the clamps were still available and now I can't find a replacement. (lesson learned)
    2) What glue should I use for the anti-squeak strips?
    3) The Quanta anti-squeak strips seem much thinner than the originals. Are they okay to use?
    4) What is the best way to refinish the filler neck? I would imagine that they were originally plated with something to avoid rust.
    Thanks again.
    • 11698
    Re: Fuel Tank Detail
    Tom,
    From my experience last year,
    1. Doc Rebuild?
    2. I tried weatherstrip cement, and that didn't work.
    3. I bought strips from Dr. Rebuild, which were very, very nice. Thick, just like originals. The ones for the top of the tank, though, are a waste of time. They just won't stay in place, even with adhesive.
    4. I had the filler neck refinished in zinc plating. I suspect they "may" have been galvanized originally, but the zinc looked great especially since I asked for it "dull" to match the original patina.
    Patrick
      • 15640
      1) I don't know
      2) The ones on my 1970 are not glued in.
      3) I don't know
      4) My guess is the fuel filler neck was originally tin plated, just like the dip stick tube.
      • Joe T.
        • October 25, 2006
        • 304
        My recollection was that my '69 anti-squeak were not glued or otherwise attached. I also seem to remember them as being like felt roofing paper that is sticky on its own? My tank is coming down shortly, so I will update this post (if I remember)
        Joe
          • 43289
          Thanks again.
          Tom-----
          1) I believe that Dr. Rebuild has the tower clamps you seek. At least, they once had them;
          2) The original anti-squeak pads WERE fastened with an adhesive compound. Whether, or not, after 40 years the "adhesive is still adhesive" is another matter. The adhesive originally used was very similar to 3M Super Weatherstrip Cement and that's what I suggest you use. Keep in mind that the adhesive serves only as an assembly aid. If you choose to not use it no one will ever know the difference. But, you'll have a lot harder time trying to install the tank and supports without displacing the strips;
          3) I don't think the thickness of the pads is going to make a whole lot of difference. However, I would expect that the Dr. Rebuild pads are probably more like the originals;
          4) As Terry M. mentions, the fuel filler neck was TIN plated. While in some ways similar in appearance to "dull" zinc or cadmium plating, it's not exactly the same.
          • Tom L.
            • May 7, 2007
            • 438
            Thanks guys. Can anyone make a suggestion for a vendor to tin plate the filler neck?
              • 3422
              Tom,
              I've been searching for the tower clamps for a long time. Dr. Rebuild had them at one time but no more. I was able to get some clamps 1 size too large and had some success cutting them down. I used 8-10 clamps to make 4 to replace the ones I couldn't save of my originals.
              The first thing I look at when I see a 71 is to check for the clamps on the return line at the fuel pump. I RARELY see them. I think the torque to loosen the screw twists and breaks the band before the screw moves and the clamp goes in the trash and a tiny worm gear clamp goes on. Of course this doesn't matter to anyone but us loonies.
              PS: I have a whole roll of roofing felt ( minus 2 strips) you can have, if you come get it. It's the heavier 30 lb felt. Are you sure you won't come get it?
                • 11698
                Tom,
                Alan,
                I think the tower clamps were mostly a 70 thing. My 71 and 72 had the green and red spring clamps everywhere - no tower clamps at all. Personally I only recall seeing them on 70s.
                Patrick
                • Joe T.
                  • October 25, 2006
                  • 304
                  Tom,
                  Are you telling me that my recollection was correct or just having some fun with my aging mind!
                    • 43289
                    Alan,
                    Patrick
                    Patrick------
                    Actually, the original fuel system hose clamps on my 1969 were ALL of the spring variety.
                    It seems strange that they would go from the spring clamps for 1969 to the tower clamps for 1970 and then back again to spring clamps for 71+. As a matter of fact, the 1968-72 AIM's all show the use of spring clamps for all fuel system hose clamps.
                    Of course, it's possible that the clamps used for 1970 deviated from specification. If so, though, I wonder if this was something that was done for the entire model year or just a smaller number of cars?
                      • 11698
                      Patrick------
                      Joe,
                      Dunno that one.
                      I just know that I would not generalize it as much as has been noted previously in this thread.
                      The cheap route is to install the green and red spring clamps and wait to see if the judges note it. If not, it's a freebie.
                      Patrick
                        • 15640
                        I don't think the clamp style changed at the model years.
                        Don't depend on the configuration of clamps or fasteners in drawings in the AIM -- the shapes in the drawings mean nothing. Check the part numbers, and chart part number changes.
                          • 11698
                          Agreed.
                          Joe Lucia, where are you?
                          I don't own all the AIMs for 69-72, but possibly Joe could provide any changes.
                          Patrick
                            • 43289
                            Terry------
                            That's what I primarily did, although I did it only for the clamps for the 3/8" lines. All 68-72 used the same part number for the 3/8" clamps. The configuration as shown in the AIM's was really secondary information although I've found it to generally be quite accurate.
                              • 15640
                              Following the part numbers for all the fuel line clamps would be quite a a task, even if restricted to 19698-1972 -- more time than I want to or can spend on the issue. You have my admiration Joe, for all the time you spend selflessly for us.
                              I was thinking of the radiator clamp changes that are not reflected in the AIM drawings for quite some time when I made the comment about clamp style changes to the drawings. Perhaps those and the changes to fastener head type have made me jaded.
