Regarding a '70, I understand, primarily from information that I've picked up on this forum, that the fuel line clips & bolts and the front brake cross over line clips and bolts should be zinc. I also understand that the clips and bolts for the brake lines that run down the left frame rail and across the 3th cross member are to be zinc oxide (black), but for the different style zinc center clip in the 3rd cross member.
My first question is whether I have it correct. My second question is what vendor carries the black oxide brake clips and bolts. I've bought two sets already and they're all bright zinc. I have the home black oxide plating kit, but the stuff won't stick to this hardware.
As always, thanks in advance for your help.
