Well At the risk of bragging I tackled and mostly accomplished my largest "single handed " project to date, and my title reflects both the mechanical and the physical problem , since I did it from underneath the car !!!
My goal was to remove the entire rear end over the weekend. Because It has always been an Arizona and California Car , and I sprayed PB on every nut and bolt Saturday Night , I had little problem with the nuts and bolts. I was able to remove the right hand side of the Shock ,Strut rod , Half Shaft,Trailing arm etc.
...........but the left hand side remains in tact.!
My Problem ... I can not remove the lower Shock mount . therefore I cant get the strut out, Etc etc. The right one came out with one whack of the hammer. The left however has been whacked so many times I am afraid I will permenantly blunt the end !! So now what, you Well -learned Gentlemen ?
Since I am not able to go to the Archives . I ask for your help !
Jim
Ps. How "bent" is "bent" on a Strut rod ? The left one appears to have a "Ever so Slight" bend in it !!
Jim
